Hydronic heat question
FullersPlumbing
Member Posts: 1
Help! I have a question about a Model PP-12NE (Paloma pak-Hy-tech) boiler. I need to know which side is the cold water return and which side is the hot water feed. Does anyone know the answer, or where I can access a schematic?
As you face the boiler from the front..
Hot on the left, cold on the right. If it is applied as a space heating appliance, it will give problems...
ME0
