Used 1 Pipe Steam Radiators in Brooklyn and Queens?
wiley
Member Posts: 16
One of my radiators needs to be replaced - anyone have any good sources for used radiators in Brooklyn and Queens - The one I need to replace is large - EDR of 35 (approx) - any info is appreciated.
problem rad
what's wrong with it?--nbc0 -
cracked
It's got a pretty significant crack on the bottom as well as a small pin hole that I'm not able to fix. It sure sends a lot of steam through those two....................0 -
Found one
There's a guy on eBay who's got two radiators for sale in Qns. He wants $150 for the pair, or starting bid at $100 if you want to wait five days. Auction number is 110621544381.0 -
thanks
thanks for finding the ebay listing!0 -
i've got one ...
26H x 7section x 5tube American Radiator "Corto" .. one-pipe steam .. needs a new spud ... bare metal, good condition ... was in service here until I swapped around some EDR. contact me directly if you like.1-pipe Homeowner - Queens, NYC
NEW: SlantFin Intrepid TR-30 + Tankless + Riello 40-F5 @ 0.85gph | OLD: Fitzgibbons 402 boiler + Beckett "SR" Oil Gun @ 1.75gph
installed: 0-20oz/si gauge | vaporstat | hour-meter | gortons on all rads | 1pc G#2 + 1pc G#1 on each of 2 mains
Connected EDR load: 371 sf venting load: 2.95cfm vent capacity: 4.62cfm
my NEW system pics | my OLD system pics0 -
found one
Just a follow up for folks looking in the future -
I found a plumbing supply shop at 525 park ave in brooklyn - they have a garage full of used radiators that have been tested for leaks - I was able to pick up a good one there -
$14 per section for 37" high radiators. - not as inexpensive as I would of liked but glad that it works.0 -
Thanks
Thanks for this. Do you have their number or name?0 -
ditto HenryT post: contact info?
perhaps Kevin Richard Plumbing: http://is.gd/iFQ1X ???1-pipe Homeowner - Queens, NYC
info
I forget the exact name - but just google map:
525 park ave Brooklyn NY - and the location and name will come up - I think it was Kevin's Plumbing supply -
they keep the radiators in a separate building - so they drive you over there (short distance) and you take a look.
good luck
If you can't find it send me a note and I'll dig deeper0 -
here it is
Kevin Richard PlumbingAddress: Not true? Show all edits Not true?
Placement on map is approximate525 Park AvenueNY 11205-1632
Get Directions(718) 222-1581
24 hour open0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
