Laars Endurance LO
smcd1969
Member Posts: 1
in Gas Heating
Hello folks,
I have a Laars Edurance boiler that just had its annual service 3 days ago. Yesterday one of the circulator pumps began making an odd noise, like its always on type deal.
When I woke this morning, the boiler is in LO and the temp in the house is 50 degrees. (I live in Maine, so this is bound to drop as the day goes on).
I have turned on/off via the control panel, I have used the reset button and also turned off the main power to the system to no avail.
Any suggestions before I need to worry about getting my 2yo and 5yo to a different location for the evening so they don't freeze?
Thanks.
Thanks.
Check water pressure and
check to make sure you has gas in the tank if you have propane.Cost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating0
- 167 Indoor-Air Quality
