Goodbye Burnham, Hello...Burnham
Finished this replacement today. Original boiler was a coal-fired Burnham, converted to oil at some point. Today, a new gas-fired Burnham IN7.
  • crash2009
    crash2009 Member Posts: 1,478
    second boiler riser
    I like the way the second boiler riser drops in to the header.  It allows for a more compact install in a tight space.
  • Danny Scully
    Danny Scully Member Posts: 1,465
    Thanks Crash!
    Thanks Crash!
  • Jim Bennett
    Jim Bennett Member Posts: 607
    Nice!......
    Cast Iron fittings, great upsized drop header. You obviously took the time to clean all the piping afterwards.
    Thats piping to be proud of!
    Jim
  • Danny Scully
    Thanks!
    Thanks Jim, I really appreciate it.
  • Oak Park Electric
    Oak Park Electric Member Posts: 46
    Looking good
    Like Jim said, a noticeable LACK of pipe dope all over everything.  How many jobs have we all seen where the exact opposite is true...     good work.  Is there a backflow somewhere on that fill line?
  • FJL
    FJL Member Posts: 354
    Pipe Doping
    What is the problem with noticeable pipe doping?  Is it just cosmetic or does excess pipe dope have some impact on how the systems runs?
  • Jean-David Beyer
    excess pipe doping
    I am not a professional heating contractor or plumber, so I have never used pipe dope myself. I have installed a lot of 1/2 inch copper tubing in my house, mostly in my darkroom. So while I have not used dope, I have used paste flux for soldering. I suspect I use too much. For the darkroom, I made 100 (I counted them once) soldered joints and no leaks. I have water filters in there, and they trapped what seems to have been flux when I first started using that. (I never eat or drink up there because it is too easy to contaminate things with photochemicals.) Those fittings that have to be threaded (vacuum breakers, mixer valves, etc.) I just used teflon tape.
    When my boiler was replaced, and the near boiler piping totally replaced as well, the plumbers used both teflon tape and pipe dope on all the threaded connections. They did not make it clear why both; belt and suspenders I suppose, but I do not actually know. The gasfitters used dope only, no teflon. Oh; the LWCO was dope-only; no teflon. But I know why that is.
    I guess too much dope is like too much flux: it gets into the piping system and that is likely to be undesirable.
  • MikeyB
    MikeyB Member Posts: 696
    Burnham
    Real nice work Danny, by any chance is the guy on the right hand side of the last photo name Peter? he looks alot like my old partner from a shop in Queens, NY
  • Oak Park Electric
    Dope
    On the outside, it's really just a cosmetic thing.  When an installer leaves a job with dope smeared all over the pipes, fittings, boiler jacket, and maybe even some on the floor,  it just looks like hasty careless work.  Even though what we do is supposed to be covered with insulation, a real pro usually takes pride in his work and wants it to be as good as it can be.  That means both functionally and cosmetically.  However, a serious over doping can cause it to get into the system, which can be a problem in things like  potable water piping or steam boilers.
  • gerry gill
    gerry gill Member Posts: 3,084
    Nice looking job.
    Clean and well installed..great job!
    gwgillplumbingandheating.com
  • Danny Scully
    edited December 2010
    Negative
    Negative Oak Park, there is no backflow. We don't usually install backflows on steam boilers. On a hot water boiler, it's the second item on my material list behind pressure reducing valve, ha. But for a steam boiler, it has honestly never come up on any inspection. I guess the theory here being the lack of pressure, although anythings possible.
    JDB, the lack of pipe dope is just me being a psycho. The best boiler installations are those that follow the manufacturers instructions, and to the best of my knowledge Burnham does not insist you remove the pipe dope from the outside of the fittings.
    Mikey, that's not Peter. Sorry! Ha
    Thanks again!
  • Danny Scully
    Thanks!
    Thanks Gerry!
