What type of baseboard heater is this?(Pic attached)
static_k
static_k Member Posts: 2
Hi,
I don't know much about heating and in my house this morning I found a nice puddle of water underneath my heater in the bedroom. I believe I have a hot water single loop system.  When I took the side cover off the heater I see the elbow pipe that looks like possible a shut-off in it as well as something else that looks like maybe a shut-off on the top. I did some searching on the net and most pictures I find don't have that smaller valve looking thing. Is that normal? Is this a cast iron baseboard? The house was built in the mid 1950's and I believe the baseboard is original.
See attached file with the picture.
I also uploaded a pic on the web so you can see it bigger if needed:
<a href="http://www.moonlightcreators.com/IMG-20101202-00136.jpg">http://www.moonlightcreators.com/IMG-20101202-00136.jpg</a>
Any help is appreciated.
Thanks!
  • Dirjone_in_SD
    Dirjone_in_SD Member Posts: 3
    Cast Iron?
    Looks like cast iron BB to me from the pic you posted?
  • Andyk
    Andyk Member Posts: 13
    Cast Iron base board
    I agree that it is CIBB, looks like Weil McLain to me.
  • bob eck
    bob eck Member Posts: 930
    baseboard
    if the fromt top is square its weil mclain if its round burnham
  • billtwocase
    billtwocase Member Posts: 2,384
    baseboard
    Looks like a cast iron core only run thru a steel jacket. I think American Standard had something like this, but definitely not full cast iron baseboard lookin at that pic
  • tim smith
    tim smith Member Posts: 2,897
    RE pic
    I think it is steel baseboard. They spot welded the face to a water jacket behind. I do not remember the mfr but I have seen that in the last year on another job.
  • Henry
    Henry Member Posts: 998
    Cast
    It looks a lot like a 50s American Std. Look here for infos:
    http://oldcastironradiators.com/radiators.htm
    Henry
  • static_k
    Re: Cast
    I think that's definitely it, Thanks Henry!
    http://oldcastironradiators.com/CastIronBaseboards.htm
    It looks exactly the same as Rad#26 in that pic.
    Unfortunately the radiator was all rusted at one end where it was leaking. Beyond repair so I had to remove the unit  and pickup a new baseboard  heater at home depot. The room had 2 heaters and the other one was working fine. Should I just throw it out or is it worth trying to sell?
    Thanks.
