Main Air Vent missing
Jerry Withers
Member Posts: 40
Hi,
I have been searching for the longest time where my main air vent is located and have come to the conclusion that I do not have one.
Then it hit me,... In my foyer I have a capped steam pipe that come out right next to one of the radiators. It is at the end of one of the longest runs. Could it be that this is where the main vent should be?
Attached is a photo I took.
Any ideas what kind of air vent I could install on this? Any problem with it being in my foyer?
could very well be...
the place .. if it wasn't originally, it would probably make a good place for one now. main vents are almost always STRAIGHT .. so perhaps you need a STREET EL, and depending on the size on that plug, perhaps a REDUCING STREET EL. or a STREET EL with a REDUCING BUSHING. or you could remove the entire elbow you have now and use a coupling + bushing.1-pipe Homeowner - Queens, NYC
NEW: SlantFin Intrepid TR-30 + Tankless + Riello 40-F5 @ 0.85gph | OLD: Fitzgibbons 402 boiler + Beckett "SR" Oil Gun @ 1.75gph
installed: 0-20oz/si gauge | vaporstat | hour-meter | gortons on all rads | 1pc G#2 + 1pc G#1 on each of 2 mains
Connected EDR load: 371 sf venting load: 2.95cfm vent capacity: 4.62cfm
my NEW system pics | my OLD system pics0 -
What kind of Main Air Vent?
Assuming that I get a bushing and a coupler to install a main air vent, which air vent would be the best to install?
How long is your steam main
and what pipe size is it?All Steamed Up, Inc.
Consulting0
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
