laking joint
midwestrain
Member Posts: 2
I have a older boiler with baseline radiators, one of the joints at the end of the radiator is leaking slightly. can i just clean it up an solder it? if not is there a way to fix this without replacing it?
typos
leaking. so sorry about the typos.0 -
It needs drained dry first
then heat it and separate it and clean it well then reassemble after it cools pressure test then bleed.Cost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating0
- 50 Industry Classes
