Honeywell Controls
newbie2this
Member Posts: 18
I am needing guidance from a Honeywell control guru...
Must be familiar with oil fired controls i.e. R845A and R4184G.
Thanks,
Newbie
Thanks,
Newbie
Honeywell Control:
You can't get an answer without asking the question. What is it?0 -
What limit
controls do you have? Those have to be wire in there too. Why not combine everything and go with a R8182 A,D ?0 -
Honeywell Control
I have and old surface mounted honeywell minneapolis LX aquastat external mounted, wired back to my R845A and then going to my R117A stack contoller.
I would like to replace my R117A with a R4184G and use a photocell that looks at the flame and seal up my stack hole.
Thanks,
John0 -
Honeywell Control
I looked at the R8182D and F model, but I have nine cast radiators in my house on a circulator, and they're on the same zone, so just putting an R4184G with photocell would be cheaper, and do the same thing. Just want to know if the R845A can be wired with a R4184G and exactly how?
Thanks,
John0 -
Control:
It's complicated. Use the triple acting control. That eliminates the RA845. Then, use a primary burner control that replaces the illegal RA117 stack switch. Eliminate the old junk controls. If it is a three wire control to the stack switch, you will pull your hair out, if you have any. You need the circulator control part of the triple acting control.
It's complicated.
I find that many electricians are clueless when it comes to boiler controls. I often must re-wire after them. It will be even more difficult to walk you through this if you don't have a background in controls. You could make a dangerous situation worse.
Find someone that knows what they are doing.
It matters not to me what you decide to do. My stuff works fine.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
