Anyone Use T-Stat with Wireless Remote Sensor?
FJL
Member Posts: 354
Does anyone have any experience with a t-stat that uses a wireless remote sensor? The one that turns up most often is a White and Rogers product (1F85RF-275). Not sure if Honeywell makes a t-stat with a wireless remote sensor. I currently use a Honeywell product with a wired sensor, but I'm thinking I might need to move it to a different location and using a wire is for that is not what I want to do. I have a one pipe steam system.
Thanks.
Thanks.
remote wireless sensor
i could use one also, and have the same restrictions as far as running extra wires. the best arrangement would be to have a connection through the house wiring like the old radio shack plug in intercoms. our walls here are so thick that a wireless radio signal would be unreliable.
i,ll be interested to see what others come up with for this.--nbc0
- 167 Indoor-Air Quality
