help identifying antique air vent
rmoore007ri
Member Posts: 45
Can anyone identify this air vent?? Probably very early. No identifying marks or logos at all.It came along with 17 radiators stored in a basement.
Ain't that special!
Is it made out of brass?0 -
the vent is brass or bronze
Yes, brass or bronze. casting marks lengthwise through the C/L of the nipple.
The adjustable pin will meet a pin that could extend from the body (on pressure or temperature - haven't put it in a radiator or pot of boiling water yet.)
bob0 -
That's a new one on me
obviously some sort of adjustable vent. Might be a Norwall or Libra or similar- the adjuster probably points up when the vent is installed, and water sits in the body of the vent all the time.All Steamed Up, Inc.
Consulting0 -
I know I have a photo of them some where
I just need to find which old parts book it is in. Walworth may be close. I do not see ones with the adjustment screw but the bodies look close.Cost is what you spend , value is what you get.
cell # 413-841-6726
Do you have photos of the radiators?
and what region they are from.Cost is what you spend , value is what you get.
cell # 413-841-6726
- 87K THE MAIN WALL
- 114 Chimneys & Flues
- 106 Geothermal
- 981 Plumbing
- 388 Solar
- 47 Industry Classes
