Firefox and Gaugestore.com DOES NOT WORK
jpf321
Member Posts: 1,568
I posted this last year, but it's worth a reminder since I just got burnt again .. if you place an order with Gaugestore.com DO NOT USE FIREFOX. The order does not go through if you use Firefox. I have spoken with Jill and asked her to look into it.
1-pipe Homeowner - Queens, NYC
NEW: SlantFin Intrepid TR-30 + Tankless + Riello 40-F5 @ 0.85gph | OLD: Fitzgibbons 402 boiler + Beckett "SR" Oil Gun @ 1.75gph
installed: 0-20oz/si gauge | vaporstat | hour-meter | gortons on all rads | 1pc G#2 + 1pc G#1 on each of 2 mains
Connected EDR load: 371 sf venting load: 2.95cfm vent capacity: 4.62cfm
my NEW system pics | my OLD system pics
I had no trouble getting to this page.
I had no trouble getting to this page all the way from the top. Using Firefox 3.6.11.
Low Pressure Gauges 2.5" Lower Mount
Low Pressure gauges are extremely sensitive and highly accurate. These
gauges are designed to measure pressure and vacuum of gaseous media from
as low as 15" H2O to 10 PSI.0 -
no problems placing things in cart ...
but you will have a problem submitting your payment info ... and completely the order .. you get bounced back to you "cart" page and the order is never placed .1-pipe Homeowner - Queens, NYC
my NEW system pics | my OLD system pics0
