Gauge Store Question
Maine Vent
Member Posts: 130
<img src="http://www.gaugestore.com/images/WIKA.jpg" width="70" height="32" alt="" />
Low Pressure Gauge 2.5", 0-15 OZ/SQ.IN.
<img src="http://www.gaugestore.com/images/clear.gif" width="1" height="10" alt="" />
Stock #:
33010
Brand:
WIKA
Series:
611.10
Mfr Part #:
9851780 The Gauge store says this gauge is not suitable for a steam boiler. Any advice on this type of gauge. I know a lot of you promote LP gauges from this company. The high temp limit is 140 degrees on this gauge. <img src="http://www.heatinghelp.com/file:///C:/Users/Mark/AppData/Local/Temp/moz-screenshot-1.png" alt="" /><img src="http://www.heatinghelp.com/file:///C:/Users/Mark/AppData/Local/Temp/moz-screenshot.png" alt="" />
Stock #:
33010
Brand:
WIKA
Series:
611.10
Mfr Part #:
Weil McLean SGO4, Riello Gas Burner
404 sq ft EDR
Old Burnham V8 Removal
404 sq ft EDR
Steam gauge
That gauge cannot be used on live steam BUT if you have a siphon between it and the boiler it should be fine. I have a gauge that is in the same series mounted on my Burnham boiler as you can see in the photo below. If you look behind the BX cable you can see the original 30 PSI gauge which has an internal siphon built into it.
3PSI gauge0 -
They told me
to get the gauge and pressure controller way up above the water line. This is how I did mine. When the boiler is steaming the pigtail gets hot (more than 140 F)at the bottom, but the top stays at room temperature. Gauge/Snubber/Valve stay about 70 F all the time.0 -
right .. what bob said ..
the pigtail protects it from live steam .. there is always a buffer of water in the pigtail .. and this is exactly why we don't use a straight nipple ..1-pipe Homeowner - Queens, NYC
NEW: SlantFin Intrepid TR-30 + Tankless + Riello 40-F5 @ 0.85gph | OLD: Fitzgibbons 402 boiler + Beckett "SR" Oil Gun @ 1.75gph
installed: 0-20oz/si gauge | vaporstat | hour-meter | gortons on all rads | 1pc G#2 + 1pc G#1 on each of 2 mains
Connected EDR load: 371 sf venting load: 2.95cfm vent capacity: 4.62cfm
my NEW system pics | my OLD system pics0
- 85.7K THE MAIN WALL
- 50 Biomass
- 75 Chimneys & Flues
- 93 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 854 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.6K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 87 Job Opportunities
- 15 Recall Announcements
