Boiler makeup water meter
arches
Member Posts: 52
Can anyone recommend a good water meter to measure makeup water? I'd like to install one upstream from my McDonnell Miller #51-2 autofeed to keep on an eye on how much fresh water is being added.
I never tried one of these, but...
when I was considering getting a water meter, I found these:
http://www.jerman.com/dljmeter.html0 -
same question .. but for heating oil??
anyone know of a reasonably priced oil flow meter?1-pipe Homeowner - Queens, NYC
NEW: SlantFin Intrepid TR-30 + Tankless + Riello 40-F5 @ 0.85gph | OLD: Fitzgibbons 402 boiler + Beckett "SR" Oil Gun @ 1.75gph
installed: 0-20oz/si gauge | vaporstat | hour-meter | gortons on all rads | 1pc G#2 + 1pc G#1 on each of 2 mains
Connected EDR load: 371 sf venting load: 2.95cfm vent capacity: 4.62cfm
my NEW system pics | my OLD system pics0 -
goto feEbay and search "aquametro diesel meter"
-i figured it would be cheaper to get the run-time hour-meter and multiply by your GPH.There was an error rendering this rich post.
try water company
if you're a cheap sob like me, you could call the water company and see if they can dig an analog one out of the water meter graveyard for you.There was an error rendering this rich post.
yes.. time * GPH .. but I'd like to
verify that as a proper value with a redundant data point. GPH can be sometimes variable .. fuel temp may cause a difference .. i'd just like to look at it from both sides .1-pipe Homeowner - Queens, NYC
aquametro diesel .. yes and no
if i'm reading the nameplate specs properly .. the aquametro diesel meter has a min flow capability of 1GPH .. unfortunately, i'm drawing below that especially with my Tiger Loop.
go anything with more precision?
thanks1-pipe Homeowner - Queens, NYC
nice find
Yup, that looks like it would do the trick!0
