4 inch flange for header
Luv'nsteam
Member Posts: 278
I am looking for a 4" flange to install my steam boiler header. I have found a couple options, but I am not sure what to do.
Pexsupply offers a 4" flange union: <a href="http://www.pexsupply.com/Ward-FCIFLU4-4-Black-Cast-Iron-Steam-Flange-Union-456000-p">http://www.pexsupply.com/Ward-FCIFLU4-4-Black-Cast-Iron-Steam-Flange-Union-456000-p</a>
Grainger offers a "dielectric" flange union that looks pretty much like the Pexsupply part: <a href="http://www.grainger.com/Grainger/WATTS-Dielectric-Union-1LPJ3?Pid=search">http://www.grainger.com/Grainger/WATTS-Dielectric-Union-1LPJ3?Pid=search
Grainger also offers an 8-hole flange for 4" threaded pipe that if I use this, I will need two and a gasket: [url=http://www.grainger.com/Grainger/Flange-4TXF9?Pid=search]http://www.grainger.com/Grainger/Flange-4TXF9?Pid=search
And a four-hole flange: [url=http://www.grainger.com/Grainger/ANVIL-Flange-4KWH2?Pid=search]http://www.grainger.com/Grainger/ANVIL-Flange-4KWH2?Pid=search
However, the gaskets I found on Graingers site for both the 4 & 8 hole flange is neoprene and will only handle up to 190 degrees: (link for 8-hole flange) [url=http://www.grainger.com/Grainger/Gasket-1TUT5?BaseItem=4CYX2]http://www.grainger.com/Grainger/Gasket-1TUT5?BaseItem=4CYX2
I am looking at Grainger because I get a large discount on parts, but getting the right part the first time is most important.
Any ideas/suggestions/guidance will be much appreciated.
Thank you</a>
Thank you</a>
Check this out
While I am puzzled no one replied, I am not one to wait patiently. That said, check this out: I just found this cast iron, American made, 4" flange union that is likely decades old but brand new! I had to blow the dust off it. Cost: $31.50, complete!!!!! Perseverance always pays off!
Mike0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 849 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
