Intrepid Install Quandry... Steamhead? Boilerpro?
jpf321
jpf321 Member Posts: 1,568
On an Intrepid TR-30... How the heck do you pipe in a MM67 LWCO with a tankless coil while still providing a skim nipple&valve as well as allow the door to open??
If I mount it on the right side, I block the skim port.
If I mount it on the left side, the door doesn't open/block tankless tappings.
Anyone have pics/solutions/ideas?  Do I use longer nipples from the tappings to the LWCO T's? How long? The I&O calls for 5" nipples, but they don't allow skmming.
This is kind of Urgent.. THANKS!
1-pipe Homeowner - Queens, NYC
NEW: SlantFin Intrepid TR-30 + Tankless + Riello 40-F5 @ 0.85gph | OLD: Fitzgibbons 402 boiler + Beckett "SR" Oil Gun @ 1.75gph
installed: 0-20oz/si gauge | vaporstat | hour-meter | gortons on all rads | 1pc G#2 + 1pc G#1 on each of 2 mains
Connected EDR load: 371 sf venting load: 2.95cfm vent capacity: 4.62cfm
my NEW system pics | my OLD system pics
