multiple controls wiring in parallel circuit
orbea
Member Posts: 1
i would like a diagram with aquastat thermostat gas valv in parallel circuit
Hmm.
Are you planning to burn out the transformer, or never shut the boiler off?
Are you referring to series wiring, instead?0 -
Series circuit my friend........
You have 1 load according to your post and the other circuits are N/C contacts and open when temp gets too hi. PLEASE do not even try this as you will probably do what the other post said............ Call A PRO.
Mike T.0
- 50 Industry Classes
