OIl burner tune up service
AJ1
Member Posts: 24
in Oil Heating
I am new HO and need a trusted oil burner tech who can do a filter removal and strainer and tune up the burner...please recommend..also what ball park to pay for the service..I called around and its around 75$.
Please help.
Thank you.
Please help.
Thank you.
Annual Service
Hi-
One of the rules on this board is that pricing is not discussed. Perhaps If you told us what type of heating system you have, someone could tell you what an annual service should entail and you can call around pricing locally.
- Rod0 -
recomendation
Sorry for asking for prices...can someone recommend a prof for burner tune up..I am in NNJ0 -
Find a Contractor
Have you tried the "Find a Contractor" section at the top of this page? Scroll down past the "zip code" section (not reliable) to the "States" section and see if there is a pro located local to you.
- Rod0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
