help with new yorker boiler
hillk
Member Posts: 1
in Oil Heating
my home has a new yorker boiler and baseboard heat. recently i ran out of oil and the boiler shut down. now that i have oil, can anyone help explain how i can re-start the boiler?
thank you
Kirt
thank you
Kirt
To save damaging any parts
Contact a heating contractor and have a tech sent over to purge the lines and give the system a look over. If you ran out before you expected it may indicate the system needs repairs it can also mean you have a leak.Cost is what you spend , value is what you get.
cell # 413-841-6726
bad idea
have someone who knows get you off and running. It may not have run out0
- 120 Geothermal
