Condensing Boiler with Indirect DHW
newbie2this
Member Posts: 18
I currently have an old 1940's oil fired burner and a 275 gal tank both in my basement. I also have a NG hot water heater. My heat system is a closed recirculating hydronic system with wall recessed radiators. 1500sq ft living area. I would like to install a NG 5to1 condensing boiler with a indirect tank for DHW. I have been looking at the Triangle tube solo boiler and the indirect tank, I have a dealer in my area that sells the Viessmann boilers, but I am unsure of who/which is the better boiler... I have looked at many to include Lochinvar, Weil McLain, Slant Finn, but of all the Prestige seems to be the best!? Cost is a concern, but so is quality, and I no of no one in the Baltimore area that specializes in these installations. Any help/advice would be appreceiated.
Thanks,
Newbie
Thanks,
Newbie
If I had to choose
I would go with the boiler whose installer services it in their sleep and comes when you call them. True of any boiler of course!
Your plan and approach is a sound one. Of the names you mentioned, I see Viessmann as the top of the line (although the price has dropped over the past year or so to be competitive), followed by Triangle Tube and Lochinvar Knight in a dead heat. This is not to disparage the other names, just a top-three listing and my opinion only. Others have theirs and with more hands-on experience than I ever will.
(I am on the design side but have installed my own heating systems, just so you know, and have specified all of the brands just named, a number of times each.)
What I like about Viessmann Vitodens is their materials (316 Ti or Titanium Stabilized stainless steel), and overall engineering. Boiler as System.
What I like about the Triangle Tube Prestige Solo: Designed by engineers from the ground-up, blank sheet of paper kind of design. Fire-tube (the others are water-tube), with higher water volume. 439 stainless, excellent quality and built-in ODR controls.
What I like about Lochinvar are the controls and intuitive interface. The Lochinvar is built around the Giannoni heat exchanger, which to me as a relatively high pressure drop, compared to the Triangle Tube. But the firing turn-down on the Lochinvar is 5:1. Viessmann and TT are about 3.5 to 4:1. Turndown and low fire on milder days means a lot to me. All are good, the Lochinvar wins that score.
The Viessmann HX also is similarly helical in design, than the Giannoni, but heavier in material mass. Both make the need for a dedicated boiler pump much more likely.
(In theory, any of these boilers could operate with a single circulator if properly sized, but the realities of variable system flows, control valves opening and closing, etc. means that you really do want a dedicated boiler circulator with any of these boilers. Too little flow and the small water volume flashes to steam you see.)
The TT offering, because of the relatively high volume tank type heat exchanger is most forgiving and voted "least likely to need a dedicated circulator" in its High School year book. But the way I like to see systems set up, a properly-sized boiler circulator will allow much greater design flexibility on the radiation/emitter side.
Still, it gets down to service and good installation. Who represents the brand you choose locally and with confidence. That would be my choice.
My $0.02
Brad"If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad0 -
Condensing boiler with indirect DHW
Thanks for your input, I have a design salesman coming by this week that sell the Viessmann to give me an estimate, I was wondering if you know or have networked with any reputable installation companies in my area?
Thanks,
Newbie0 -
If not the Boston area
probably not."If you do not know the answer, say, "I do not know the answer", and you will be correct!"
