Power Burner Replacement
Room4U
Member Posts: 1
Trying to identify who makes this residential ,natural gas, power burner, the label on the boiler jacket says Shephard Heating Company in Terre Haute, IN. The burner is not lighting off good and flames shoot out the back end. All appears to be okay but since it is probably 45+ years old i want to replace it. Can anyone suggest a suitable replacement. Thanks.
A new boiler is due
That is a conversion burner and is probably in a boiler never made for gas. It may be a coal or oil boiler. Gas companies in your area may have parts for it but it may be a very poor investment. Carlin makes a good gas power burner but I am not sure it is worth putting into your current heating plant.Cost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
