AIR IN THE SYSTEM
GREENMAN
Member Posts: 25
in Gas Heating
IM WORKING ON A UTICA BOILER WITH ONE PIPE SYSTEM SOME ONE ADDED A ROOM OF BASEBOARD AND THAT ROOM WAS NOT GETTING HOT AND SO I USE A MONOFLOW TEE AT THE RETURN OF THAT ADDED BASEBOARD THEN THEY WANTED A NEW ZONE IN THE BASEMEN SO I DID A NEW ZONE THERE BUT IBLEED ALL THE BASE BOARDS AND THE BOILER BUT I CAN NOT GET HEAT IN SOME OF THE BASEBOARDS NOR WATER OUT OF THEM THAT IS THE ONES WITH NO HEAT CAN ANY ONE HELP BEEN THERE 3 DAYS HELP
Air
or no heat ? the T's on a monoflow are supposed to be spaced apart roughly equal to the length of the baseboard. And I beleave you might need two mono t's to get the water to travel down hill to the basement floor.Did you bleed the system w/ 25lbs of water pressure?0 -
ZONE
I DID BLEED THE SYSTEM WITH ABOUT 15 PSI BUT THE PROBLEM IS IN THE FIRST FLOOR NOT THE BASEMAN ITS FUNNY BCAUSE I HAVE HEAT IN THE BASEBOARD I HAD NO HEAT BFORE BUT NOW I DONT HAVE HEAT SOME WERE ELSE I CANT EVEN GET WATER OUT OF IT THANK YOU FOR YOUR REPLY0
- 50 Industry Classes
