Safe to turn on heat?
tiffay108
tiffay108 Member Posts: 1
I recently got my own apartment for college and it has a hot water
heater and a circulating pump to get the water to the radiators. Well, I
turned up the thermostat for the first time today and went over to the
boiler room and noticed the the black needle on the altitude gauge of
the water heater was a little higher than it was earlier (about 29 for
pressure..i'm assuming psi, but there weren't any units on it). I
checked about 5 minutes later and it was 32! It kept on increasing and
was already in the "danger" zone when it hit 30. I freaked out and
turned down the thermometer...but I obviously don't know much about
heating/cooling and was just curious as to why it's reaching this
"danger" zone and what I should do? The maintenance man never told me
what to do regarding the heat and when I mentioned a problem with the
circulating pump before (it constantly runs all the time) he said he
needed to install a new thermostat but never got around to it. I
asked this question on yahoo answers and received an answer saying the radiators probably need bled. My question is however..is it safe to turn the heat up until the maintenance man get's a chance to fix it? I really appreciate the help!
    Steamhead Member Posts: 18,208
    I wouldn't use it
    until it's fixed. There might be a problem with the expansion tank, the safety valve, or both.
    Consulting
