LG mini splits
liro
Member Posts: 2
I have an LG LMN095hvt with an error code C7. Does anyone know what it means?
Thanks
Thanks
Multiple Indoor Units?
If your system has multiple indoor units, this code indicates that the different indoor units are set to different operating modes. For example, one unit is calling for cooling while the other is calling for heat.There was an error rendering this rich post.
LG mini split
Thanks Eugene, that was exactly what was going on. Went over to the customers and that was the problem.
Another contractor in town has a mini split single unit from LG that has a flashing code. 5 flashes. Does this mean low refrigerant?
Again many thanks for your help.0
- 123 Chimneys & Flues
