infloor heat
worm
Member Posts: 1
I am going to build a new house.1600 square ranch with walk out basement.In-floor heat in the basement only. I am wondering what you guys think of the Navein tank-less water heater combi unit.
It's a Water Heater
In some towns you cannot use it for heating. Must have the "H" stamp as a boiler. Check with your local building dept. Personally, I have an issue with using a water heater as a boiler.There was an error rendering this rich post.
- 86.8K THE MAIN WALL
- 56 Biomass
- 109 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 966 Plumbing
- 385 Solar
- 15.3K Strictly Steam
