Weil Mclain Ultra gas and 11 zones
Rich P_3
Member Posts: 34
My co-worker is installing a WM 310. this building has 11 zones using honeywell ra89 relays ( no end switch). Can we easily configure the PHD control to run strictly off outdoor temp or flow or something. Or update the relays? Any input appreciated.
Rich P
Rich P
Is that an old W-M Ultra 310?
I ask because it is my understanding that the PhD control was last used in the Ultra-2 series, and the Ultra-3 series has been out about 2 years now. Ultra 3 boilers have a very different control. You may wish to seriously examine the installation manual on how to configure that.0 -
phd control
Hi JD:
I didnt take the manual with me. I looked on line and the supplement said 2010.
I am not all that familiar with this set up. I typically install the System 2000
thanks for any help
Rich P0 -
Installation manual for Ultra 3 boiler...
The manual for the Ultra-3 is here:
http://www.weil-mclain.com/en/multimedia-library/pdf/weil-mclain-pdf/products/boilers/gas-boilers/ultra-series-3/ultra-series-3-boiler-manual.pdf
and the manual for the Ultra-3 UE is here:
http://www.weil-mclain.com/en/multimedia-library/pdf/weil-mclain-pdf/products/boilers/gas-boilers/ultra-series-3-ue/ug3_boiler_manual.pdf0 -
Ultra controls
Why don't you simply contact your local Weil Rep and get him on the job....???
Situations like this are what they are paid for. I have never been refused help when asked for.........0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
