Burham Boiler
tim_20
tim_20 Member Posts: 41
Hey guys gotta replace a section in a burnham hot water boiler. 14 sections any suggestions to make the job go easy??  1 section middle of boiler has leak. looking fo some tips to make my life easier on this one. thanks Tim
  • BMK
    BMK Member Posts: 5
    BMK
    I use chisels to spiit the boiler apart at the leaking section and then use the chisel to cave in the nipples to remove.
