adding extra btus to boiler when adding aqua booster
Giancimm
Member Posts: 1
When sizing a boiler for a home, do you have to add extra BTU's if adding an aqua booster?
The universal answer.
It depends. If you have a small house with a tight envelope and three bathrooms with whirlpool tubs you plan on using a lot then yes. If you have a big drafty home with 1 and 1/2 baths and a stand up shower then no. Where do you fall between those two?Cost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating0
