Solar melt down
Paul Pollets
Paul Pollets Member Posts: 3,671
The Imcolok 3/4" wall neoprene insulation melted between the time we climbed down the roof after installing the 30 tubes to start up the pump module. (Less than 7 minutes) The collector was at 260 F. The system stabilized within 10 minutes at 115 at top of collector. The system can be seen in the Solar category.
  • Mark Eatherton
    Mark Eatherton Member Posts: 5,875
    Hot, Hot HOT!!!
    Melted my share of that stuff. Have since resorted to real rubber insulation (Donkey u know what). It gets a little crisp on the inside, but doesn't melt through like that other stuff does. Has to be protected from UV degradation (painted).
    7 minutes eh...
    ME
  • Paul Rohrs_14
    Paul Rohrs_14 Member Posts: 80
    Propress
    Hey Paul,
    Are using the Propress fittings with the FKM seal?
    Paul
  • Paul Pollets
    ProPress
    The fittings are ProPress...nver had a problem with any leaks on glycol.based systems.
  • Paul Pollets
    Insulation
    I had some 1" wall fiberglass at the shop with some Zeston cover.  No worries for meltdown now.
  • pipe4zen
    pipe4zen Member Posts: 108
    HT insulation
    Imcolock and others also make hi-temp insulation. I special ordered
    some for my solar piping 3 1/2 years later , still looks good.
  • pipe4zen
    HT insulation
    hot_rod Member Posts: 26,638
    XHT
    extreme high temperature insulation is now available from some brands
    Armacell has a UT (ultra temperature) UT SolaFlex product out now. Not for the faint of pocketbox!
    Fiberglass works, keep it dry.
    hr
  • TonyS
    TonyS Member Posts: 849
    Aeroflex
    This stuff works great and is reasonably priced. I use the stuff with the lap seal, it is uv protected and good for 300 f continuous. once you stick the lap over the seam it never comes off!!
    http://www.aeroflexusa.com/products/aerocel_epdm/
    EPDM rubber based insulation
    is comfortable to about 150C @ 300F. Flat plate collectors stagnate above that, evac tube WAY above that.
    Once the rubber turns crunchy the insulative value is about gone.
    New solar insulation options include fleece, mineral wool, polyurethane,, polyolfins, silicone, and high tech aerospace products like Aerogel.
    There are a bunch of low quality solar insulated tube sets on the market. They claim to be EPDM, but in fact are a very low EPDM %, blend. We have tested some solar products that harden and crumble at 200F! Still others that turn to goo at 250F.
    A good solar insulation needs the temperature rating, and also has to be water tight when exposed to outdoor conditions.
    hr
  • Ross_7
    Ross_7 Member Posts: 577
    Mineral Wool
    What about mineral wool for insulation? It doesn't get ruined when wet, and is suitable for steam heating temperatures. Just curious. Thanks!
    sure, mineral wool works
    it is used in a lot of flat plate collectors still. It needs to be dry, of course.
    hr
