Can't get old pipes apart
Shemp
Member Posts: 45
My house has a 100 year old 1 pipe steam system. I have to move a radiator and the pipes are stuck so badly that I think they will break before the threads loosen.
Any tips or suggestions on how to get the pipes apart would be greatly appreciated.
Thank you.
Thank you.
Cast Iron Fittings
With a system this old, the fittings are probably cast iron. The fittings are easy to break by holding a heavy hammer on one side and whacking the other side with a large hammer. Using this method, little collateral damage will be done if there is room to work.0 -
pipes
Ok, But I can't get the pipes loosened from the rad itself.
Is there a way to get the pipe detached from the rad without damaging the rad?
The pipe is bending from the force and will not give from the rad.0 -
Pipes
If the pipe going into the radiator is stuck, you can cut it off fairly close to the radiator and use a hacksaw blade or sawzall on the interior of the pipe, being careful to stop when you are down to the threads. Then use a cold chisel to fold the pipe wall inward-at this point the piece will thread out. This method will usually work without damage to the radiator threads.0
