Cycling Evolutions?
NRT_Rob
Member Posts: 1,013
Anyone using Phoenix Evolutions or Solar evolutions seeing short cycling?
Have a contractor describing it to me during low load heating times. I suspect a sensor may be getting "spoofed" by low return temps from the heat exchanger.
This would be a major disappointment if it's a regular issue.
Rob Brown
in beautiful Rockport Maine.
can you adjust the
differential on the control? maybe it is set too tight.
hrBob "hot rod" Rohr
Living the hydronic dream0
- 62 Biomass
