oil/gas conversion
captpete12
Member Posts: 11
i have ripped out burnham boiler v-906 and replacing it with a new gas burnham 5b boiler 5007. the water line on the v-boiler is 41.5 inches from the floor, the new 5007b boiler is 27.5 inches. will this change my tee height on my hartford lood, or can i raise the height of the new boiler to me the old height.
you need to make sure the
A and B dimensions are ok. Do you have wet or dry returns?Cost is what you spend , value is what you get.
cell # 413-841-6726
boiler piping
the a dimension has plenty of height, and the boiler hes a wet return. help me on this b dimension please.0
- 120 Geothermal
