Hyrdronic heat with a Steam System
DJ_209
Member Posts: 1
I have heard that there is a way to use hydronic toe kick heaters with a steam system. It is a bit tricky but it can be done. I am redoing a kitchen and there is no wall space for a conventional radiator. How can I use hydronic toe kick heaters and tie them into my existing steam system?
HW Zone
Hi- Here's a link that might be of help to you.
http://www.bellgossett.com/Press/BG-waterzone.asp
Maybe the pros on here could comment on what enhancements ( pumps, valves, controls etc.) they would make to improve this design.
- Rod0 -
We always use
some kind of heat exchanger so the zone can be pressurized and it keeps the steam boiler water out of the small passages of a kickspace heater. That B&G would do a job pumping through that if it were a direct pump which it would need to be if no heat exchanger is used.Cost is what you spend , value is what you get.
cell # 413-841-6726
adding another hot water zone
I am also interested in adding a hot water zone to my steam boiler for the purpose of adding kickspace heaters in my new kitchen. I already have one additional zone running off boiler for an indirect hot water supply. Can I add another zone to my Burnham boiler? Could I use the existing zone running the hot water supply?0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
