Odd Radiator
If I could find my copy of EDR, I probably would not have to come to The Wall, but I need the answer in less time than it would take to buy a new copy -- or to find the oine I already own..  So ... does anybody recognize this beastie?  It is about 14 wide X 22 high and 3" thick.  If someone could send me the EDR rating, I would really appreciate it.
Thanks
Dave Elovitz
  • Dave in QCA
    Dave in QCA Member Posts: 1,805
    never seen one quite like that!
    I can't come up with the manufacture's rating of that very unusual wall radiator, but I would assume that it is probably about the same as the American Peerless wall radiator of about the same dimensions.
    Their Type 7A radiator measuares 13 5/16" x 21 7/8" x 2 7/8"   It had a surface area of 7 sq. ft.
    Information comes from American Peerless Wall Radiators, copyright 1920.
    Hope this helps.
    Dave in Quad Cities, America
    http://grandviewdavenport.com
    Steamhead Member Posts: 17,953
    That's the H.B. Smith "X-Ray" wall radiator
    the rating for that one is 8 square feet. And yes, it appears in "E.D.R."
    Consulting
  • Dave Elovitz
    Dave Elovitz Member Posts: 7
    Thank you
    Thanks for your help.  I really appreciate it
    Dave Elovitz
