Bacterica in Condensate
TJ_5
Member Posts: 71
Good day, Have a large steam system 3 60+ HP boiler running 100# steam to a campus. 2 outside loops for steam and condensate. Chief of plant has found Fibrorous (sp) red iron bacteria in the renurn. it is believed to be on only one of the loops, it is showing up in the DA tank where it subsequently dies and clogs strainers valves and just about anywhere it can rest. They are checking for an agent to mix into chemical feed to battle the growth. Anybody got an idea??
Condensate Problems
You might want to contact Rhomar http://www.rhomarwater.com/ They are good guys to work with and very helpful.
- Rod0
- 167 Indoor-Air Quality
