priming my oil gun
jpf321
Member Posts: 1,568
while i was away the last few days, my HW heating caused my oil tank to run dry...i have ordered more oil for tomorrow but I wanted to see if there is anything special that i have to consider when priming the gun. is there a best-practice procedure for getting the gun primed? I have 2-pipe oil setup with an inground tank. right now the primary controller is blinking green light near the red switch. I have a Beckett SR gun.
thanks,
jpf
thanks,
jpf
1-pipe Homeowner - Queens, NYC
NEW: SlantFin Intrepid TR-30 + Tankless + Riello 40-F5 @ 0.85gph | OLD: Fitzgibbons 402 boiler + Beckett "SR" Oil Gun @ 1.75gph
installed: 0-20oz/si gauge | vaporstat | hour-meter | gortons on all rads | 1pc G#2 + 1pc G#1 on each of 2 mains
Connected EDR load: 371 sf venting load: 2.95cfm vent capacity: 4.62cfm
my NEW system pics | my OLD system pics
Prime
If you are sure you ran out of oil, it will prime itself with one or two resets.0 -
thanks
thanks TB .. yep the stick measures 1.75" .. i'd call that run out.1-pipe Homeowner - Queens, NYC
my NEW system pics | my OLD system pics0 -
If it does not start
you will need to do a manual bleed of the burner. do you have the installation manual still?Cost is what you spend , value is what you get.
cell # 413-841-6726
oil burner priming
If resetting the burner does not work try following the instructions on this link -
http://www.jimkernsheating.com/prime
You may also have to clean and replace the oil line filters at the tank and the oil pump. Make sure you have something to catch the oil so you don't end up with oil all over the place.
bob0 -
thanks for the comments
thanks for everyone's comments .. i hit the burner button 1x and then a 2nd time and everything has been good since.
my goal is to replace the boiler and burner by sept so I will have the fire fine tuned and adjusted at that time on the new system.
thanks again.1-pipe Homeowner - Queens, NYC
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
