viessmann Vitodens 200-W, WB2A
craigtaylor2006
Member Posts: 1
hey i am having som issues with the outdoor sensor i have replaced it and the wire twice now and i still get a fault code from it not sure what to do next any thoughts
I take it
you checked resistance and the sensor is within limits? If so you may have a bad VR20 board. Providing all your wiring is correct."The bitter taste of a poor installation remains much longer than the sweet taste of the lowest price."0 -
I have the solution
Put in a Triangle Tube Prestige Solo... hahahahahahah0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 879 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
