Asbestos vent pipe??
Timco
Member Posts: 3,040
Just looked at a house (1850 or so) that has a pipe burried in the wall that is super hard but not metallic. I chipped a bit off the edge and it is fiberous. Ever seen a totally asbestos vent pipe? New to me.
Tim
Tim
Just a guy running some pipes.
Transite....
We see some transite vent pipe here. (concrete - asbestos) One customer has a five story commercial building with it venting the boiler.
They used asbestos in just about everything.
JimThere was an error rendering this rich post.
Transite
We used tons of it for venting gas furnaces and boilers in the 60's. We also used it for duct work in concrete slabs.There was an error rendering this rich post.
Transite removal
I have Transite vent pipe for my Hot Water Heater. I need to reroute the roof vent, and would like to replace it with 3" B pipe. I'm curious if I can remove the Transite without busting up my wall, or if it can be pulled up from the roff/attic, or pulled out from the basement.0 -
removal is pricey, proper encapsulationmight
work , if possible0
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 948 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
