Heat Pump for Unico System
MacPHJr
Member Posts: 66
I'm looking for a good heat pump that works well with the Unico Air Handlers. Any preferences?
unico heat pump
i dont have any preference,we use lennox.Whatever brand condenser you use, make sure your airflow is ok,at least 7 outlets per ton,static 1.5'wc,or else in heating mode you will have nuisance hi press lockouts.0 -
unico heat pump
