ecm motor
joe_61
Member Posts: 21
Have Rheem M/N RBHK-17JOONHE Air-handler. Unit has ecm motor 220 volts.Connect 220 volts to unit,blower motor run continously with out low voltage wires connected.What is wrong.
ecm motor
how long did you let the motor run for? Is there a jumper wire on the low volt term board? are the internal lo volt wirers chaffed together or a screw thru them? are " the lo volt wirers not connected " mean the wirers to the motor or the lo volt wirers from the lo volt terminal board to the stat?0 -
ecm
motor low voltage hooked up to IFC board on pin connectors.Stat. wires not hooked to IFC board, only r and c from transformer.0
- 87.7K THE MAIN WALL
- 127 Chimneys & Flues
- 121 Geothermal
- 79 Pipe Deterioration
- 396 Solar
- 17 Recall Announcements
