what kind of steam trap?
BobbyG
Member Posts: 79
fella brought this picture in and ask if we knew what the cost to replace it is....
I found out the operating press. is 50 lbs and I will get pipe size, capacity and application. But I haven't ever seen a trap like this? I told him to take the lid off and take a picture of the insides....
Anybody have any experience with this type? Can you point me in the right direction?
Thanks in advance!
Thanks in advance!
ask him if there
is a name anywhere on the casting, or a riveted tag... that would help.gwgillplumbingandheating.com
Looks like
it might be a Sterling F&T trap.All Steamed Up, Inc.
Consulting0 -
Not a great picture....
but it looks like a Bestobell delta element trap. Maybe a GM3.
http://www.bestobellsteamtraps.com/pages/products.html
http://www.bestobellsteamtraps.com/literature/deltaim.PDF
JimThere was an error rendering this rich post.
Larry
There are many companies that make this type of trap. Try Gestra or Spirex Sarco. It is a thermostatic with dynamic clack type trap. I hope that picture is from the overhead and the trap station is not mounted in the vertical.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
