Hows It Work
Rich Davis_2
Member Posts: 121
Just wonderin' what is used to sense the D/P when using a variable speed circ. ie: Alpha
Amperage...
All things being equal, amperage is a point of reference and control on most ECM VS pumps on the market.
There are some pumps on the market that can receive a 0 to 10 VDC control signal that can be generated by a DP control or a DT control.
Bottom line, the DC ECM motors are MUCH more efficient than what is the norm, and throw in the ability to do VS, and you have the ultimate in wire to water efficiency with significant potential energy reductions to boot.
ME0 -
Not Quite What I'm Looking For
Basically, what is used to montor the pressure? Are there pressure transducers T'd into the supply and return, or is it done in some other way. Thanks0 -
See if this
Can help you out Rich. The link below has some nice info and I attached a white paper.
http://net.grundfos.com/doc/webnet/poweredby/gpu/US/alpha2.htmlThere was an error rendering this rich post.
- 110 Chimneys & Flues
- 106 Geothermal
- 978 Plumbing
- 387 Solar
