domestic hot water
delco
Member Posts: 2
<span style="font-size:16pt">Tying in a aqua stat on a re-circ line of domestic hot water which terminals do you bring the power in on the aqua stat i realize you go from r and w to the circulator but where does the main power go</span>
Huh???
The HOT goes from the power source, through the switch gear (OPEN on rise) and then to the HOT connection of the pump. The neutral or COMMON then goes from the pump back to the power source.
HTH
ME0 -
domestic hot water
THANK YOU0
- 123 Chimneys & Flues
