Three phase
Paul S_3
Member Posts: 1,292
I was working on a semi hermetic compressor Three phase and I noticed that each winding had two wires to it and it was connected to two different contactors why is that??
ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company
347-692-4777
ASMHVACNYC.COM
Part winding start
The two windings are probably for part-wimding start to reduce the starting current.0 -
three phase
paul, was that each winding[3] has two wirers to it ,or,is it two set of 3 windings [3 phase] that has three wirers per [3] winding?If it is two seperate sets of 3phase windings then as Tom said it is a part wind start compressor. The first contactor energizes and gets the compressor moving and a timer brings the 2nd contactor on a second or two or three later bringing the comp upto full speed. It prevents a massive amperage draw by trying to start the comp with a single contactor. Heaven help you if you miswire the 2nd contactor and reverse the rotation of that set of windings.0 -
Partial Winding Start
Sounds like you were looking at a part winding start.0 -
What model
What brand and model was it? Copeland electrical handbook has a good diagram for the wiring.0 -
Tom B/ and Terry have it.
Older Carrier and Chrysler systems also used this. If you look at this same set up today, meaning the way it starts and runs, Most simi's start unloaded and use either a electrical Bypass unloader, Hot gas unloader, or Suction unloader....And I'm sure the last one is incorrect since it's been a while///////////// Techman, How the hech have you been? Keeping busy?
Peace
Mike T.0
- 15.8K Strictly Steam
