heat loss calculation
boilerbob
Member Posts: 4
I am trying to find a heat loss calculation for a radiant floor job I am to submit a bid on. Is there somwhere on this site that could be of help? Could someone point me in the right direction? Thanks
Are you looking for a program for free?
That may be a problem as most all (reliable), websites that I know-of charge for this engineering software. :-)0 -
Work with
your distributor. They may have knowledgeable staff that already posses the software and the skill to do it properly and if not, he will probably know someone that does like a local rep.Dave H0 -
LoopCad
offers a free 30 day trial period. http://www.avenir-online.com/avenirweb/Corporate/AvenirHome.aspx0 -
reply
Thanks for the input. I called the tubing manufacturer and your right, they want to charge you. I also have used a local rep in the past but one time I actually went to their office and the salesman did not use a computer program. He just said " 100,00 btu should do it". I was not to confident with that reply. I will try Loop Cad.0 -
reply
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
