Reflective material
Jim Pompetti
Member Posts: 552
Material. Has anyone found a good thin reflective material for behind radiators
Aluminized Mylar
Metallized PET film won't tear like foil and can be adhered to the wall or removable 1/8" hardboard panels. McMaster-Carr has it.0 -
reflective material
Jamie...I went with the foil on one side and kraft paper on the back...you can find it on the net in 1000' roles for 10-20 cents a square foot. We purchased a truckload a couple years back and it works well for us. I can show you a role if you need to see it...John0 -
Is this the same John
of Laurier?All Steamed Up, Inc.
Consulting0 -
reflective material
it is....still dreaming of inventing a vacuum system so I can generate steam at 170 degrees!0 -
Well it's good
to hear from you!! How ya been?All Steamed Up, Inc.
Consulting0 -
reflective material
we've been well. Been playing around with solar hot water for pool use . Our primary concern is still the Winter load, which is why I've been reading up on the use of vacuum in steam systems. It seems the problem is in intermittent firing(hence the use of Gorton's, but why not have something wired to startup which helps to pull air out of the system, and which then shuts off(after 5 minutes or so. THis would further spreed steam to the radiators. But the Holy Grail is still steam at 170 degrees-that's what I'm after. Thoughts?0 -
The Broomell system
originally routed air into the chimney, where the draft produced a slight vacuum that helped pull air from the system. Any more than that though, and the water seals would be sucked dry from too much ΔP across them, which would cause banging etc. You'd really need to change to thermostatic traps if you wanted to pull more vacuum. Of course, this would result in much more mechanical complexity and more repairs down the road.
It might be more practical to invest in some TRV kits for your rad valves. These are used to keep certain rooms such as bedrooms cooler than the main living areas of the house. I believe Tunstall can supply these as they do for most Vapor valves.All Steamed Up, Inc.
Consulting0 -
stick em up
When reflector will be unobtrusive, including within/behind radiator enclosure, I've used "broiler" rated foil and FSK-like foil that has reinforcement, both of which are less crinkly (sp?) than standard aluminum foil. Broiler foil can be stretched tight & tacked at corners with double-faced foam tape as marketed to hang pictures.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 58 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
