Coring 3" holes
TonyS
Member Posts: 849
I have a job coming up for 5 minisplits in an old farm house with brown field stone walls. Anyone have some good methods of drilling 3" holes in stone walls?
Coring stone wall
If you call around you should be able to find a concrete coring company. They should be able to quote you a price to come out and core the stone for you.
If you live in a small town you may have to look into doing it yourself. I have cored concrete with a rotohammer and a coring bit that looked a lot like a really long holesaw that hooks up to a garden hose. You might be able to rent one from the local equipment rental center.0 -
Rough job TonyS,,,
Be sure to keep the bits relatively cool,,, meaning always clean the core out & keep a vacuum handy to withdraw the "tailings" in between.. :-)0 -
Nope,,,
When I came across that I "rented" the equipment, and never had a preference,,,, I just wanted the holes drilled,,,, lucky-me.. I may have to drill 5 a year :-).0 -
True Stone walls
If so the house could be balloon construction ??? Drop the lines into the cellar ... Heat sink the inside head line set and braze the connections , leave a slack loop in the cellar ...I have enough experience to know , that I dont know it all0 -
True Stone walls
"If so the house could be balloon construction ??? Drop the lines into
connections , leave a slack loop in the cellar ..."
I`m lost Ed,,, what are you talking about????0 -
Balloon Construction
Most stone houses used balloon construction inside wall with no insulation ... It's a clear path into the cellar ... Then look for a way out side to the condenser ... Chisel a hole and patch it behind the condenser ... Just another possibility for him ... If so its a very clean job
Thinking out of the box , rather then diagonal core drilling ....I have enough experience to know , that I dont know it all0 -
Dyna-tech
Dynatech bits and tool rock. I own a drill and about six different size bits. I've drilled stone, reinforced concrete with 1/2" rebar, and asphalt. I use it exclusively as a hand drill which requires a fair amount of effort. If you plan to do alot of drilling, buy the drill press att.achment. When you hand drill, you can drill at any angle, 45's or whatever you want. You can also drill just a partial diameter hole. For example you can drill just half of a 3" hole to a half moon shape if you want. Worth every penny you pay0 -
I called Dynatech today
The man I talked to was Glenn, very helpful. He explained that wet drilling offers speeds up to 3 times as fast as dry coring if that is an option. What I'm going to do is lay out the units inside and then punch a 3/8 pilot hole to the outside, then take some plumbers oakum and plug the hole from the inside after all five units have a pilot hole I am going to wet core the holes with a handheld machine and a lift. They have some good videos on their website that show different procedures. I will let you guys know how it goes. Going inside the wall was not an option but it was worth taking a look.0 -
Steve
have you ever used the drill press option on a stone wall. This wall is pretty uneven and I was wondering how well the levelers work.0 -
anyone tried
this kind of bit
http://cgi.ebay.com/3-concrete-core-hammer-drill-bit-drills_W0QQitemZ320505235248QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item4a9f99c730#ht_1274wt_1119
with a rotary hammer? I have a 1" Bosch rotary hammer & was thinking to try this but would prefer not to waste the money if the bits won't do the job. stone can be pretty tough, I know, - I was just thinking of using this for block or concrete ...0 -
royboy
I use those type of bits with my Bosch SDS max for drilling 2" oil lines. block is a piece of cake, concrete can take a while, stone will be difficult. I'd be hesitant to buy that on ebay, asI'm used to paying over 200 for good bits. Kinda like some of the mail order tools, thay look good in the flier...0 -
yeah, I know
sometimes eBay can be a deal, sometimes a waste of money
where do you get yours?0 -
Thin wall cores
for a hammer drill. I have them for a sds hammer drill. I use it for 2 and 3 inch holes in block and brick for vent terminals. They work ok for the softer stuff but they always break out the back of the hole. The nice thing is they fit in a lightweight hammer drill that is easier to hold on a ladder. I tried them in a hard stone facing and it took forever.0 -
They are nice
I too, like Chris use this set up with my Bosch. I have even gone as far as wearing them out, then having the carbide teeth replaced. Nice option. They are available at most reputable tool centers. Don't let the cost deter you too much if you already have the drill, they last a long time and are a cheap alternative to standard core drill."If you don't like change, your going to like irrelevance even less"0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
