Contractor
Boxcar
Boxcar Member Posts: 1
Any problems with Triangle Tube wall hung boilers propane fired making a howling noise on low fire ? All parameters are in place and unit is piped per manufacturers recommendations. Not allowed to adjust gas /air ratio .Thanks for any input .
Boxcar
  • Big Ed_4
    Big Ed_4 Member Posts: 3,530
    It's a Wonderful thing ...
    .… tech support ... Call them from the job and work it out with them ...
