Lead Abatement ?
Jim Pompetti
Jim Pompetti Member Posts: 552
Has anyone hear of this new amatory training , that MUST be done by April 1 2010
  • Larry (from OSHA)
    Larry (from OSHA) Member Posts: 742
    edited March 2010
    Well, there's this:
    Here's a link to an article about the rule:
    Read it here:
    http://www.professionalequipment.com/images/email/html/100301-email-all.html?source=pe100301-news
    And there is lots of talk on an electrical board.  Read it here:
    http://forums.mikeholt.com/showthread.php?t=123808
    Larry
  • Well, all I can say is,,,
    I think it`s ridiculous,, a perfect example of high salaries paid to government employees to think-up "dumb mandates" we all must pay-for,,, job security at its best! :-)
  • Jean-David Beyer
    I think it`s ridiculous ...
    This kind of regimented nonsense is not restricted to heating, or to the U.S. government.
    In the European Union, they do things just as dumb. Pipe organ pipes are made of a lead-tin alloy (most of them) with around 50% being lead (though the amount varies depending on the type of stop). And these days organs are provided with air under pressure created by electric fans. So ...
    http://www.nytimes.com/2006/03/22/international/europe/22organs.html
  • Constantin
    Constantin Member Posts: 3,796
    Just spent a weekend...
    ... stripping lead paint from window sashes and pulling out 80-year old
    caulk while volunteering for a pre-school house renovation. Everyone
    thought I was nuts for wearing a 1/2-face respirator, nitrile gloves,
    etc.  (I brought my own)- they went for simple N95 masks, no gloves,
    etc. instead.
    We had a talk about lead during lunch on the job site and one volunteer
    mentioned a neighbor whose kid got acute lead poisoning on account of
    contractors tracking lead dust from parts of the home under
    reconstruction into other parts of the home where there were babies
    crawling/hoovering the floor. So job-site cleanliness is one factor, as
    is occupancy. I'm sure none of the contractors did it intentionally,
    they just didn't know better. A good family friend of ours also got
    acute lead poisoning from a crumbling porch paint job when she was 2.
    Many folk doing exterior and interior paint stripping pay no attention
    to where chips go, potentially contaminating a large area, when lead
    containment is easy - shop vacs not only contain the stuff so there is
    less mess to clean up afterward but also help with sanding by sucking
    away anything airborne that could get in the way. Yeah, having to handle
    a long hose is not a lot of fun but neither is picking up stray flakes
    in the back yard.
    Lastly, I see a lot of this lead awareness re: sanding products as a
    increasing fear of industry re: falling down the same path as all the
    asbestos manufacturers. I.e. everyone and their uncle getting sued
    because some product at some time may have contained minute amounts of
    asbestos. Hence all the warnings on sandpaper. I'm not sure what the
    best answer is re: lead abatement awareness, what would you suggest
    instead of mandatory classes?
  • Dave Yates (GrandPAH)
    Dave Yates (GrandPAH) Member Posts: 281
    once again
    Went through an all-day course years ago because the local inspector for HUD said any of us bidding their work would need the cert. No one but me showed up for the class and it was, as I imagined, mostly common-sense that applied. But, I did learn a few things & it wasn't a total waste of time. The other attendees were all landlords or apartment managers.
    But, here's the real kicker. As the only certified contractor bidding the HUD work, I thought that might give me an edge. However, the inspector tilted the playing field so that anyone could bid the work. The rule was: if your work required you demo more than 1 square foot of material with lead-based (or suspected to have) paint, the lead abatement rules applied. The inspector held up a sawzall blade (to the group bidding) and told us his interpretation was it would take a ton of cuts to demo 1-square-foot of material and the only thing he was going to consider was the width of that blade! I let that go back then.
    But, given the fact that my previous cert will not be recognized and that I will be attending another (what I suspect will be a repeat) class for hundreds - once again - if the next inspector pulls the same hokey notion of what constitutes demolition of lead-based materials, there's gonna be hell to pay.
  • Constantin
    Fair is Fair
    While that inspector may give you more trouble in the future for daring to challenge him and/or causing loss of face, it is your right to insist he/she do their job as intended instead of making up interpretations to suit their needs as they go along. Given the quality of work you and your crew do, the added 'heat' shouldn't be the problem!
