Sizing Pump for Hot Water Radiators.
JStar
Member Posts: 2,752
How do you figure your head pressure for a system with all converted hot water radiators?
Pressure drop
If they are old-style column-type radiators, the pressure drop is minimal since the passageways are large.
Figure your pressure drop through your boiler and piping and then add a couple of feet of head.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Here's an article that may help
especially if this is a converted gravity system:
http://www.heatinghelp.com/article/11/Hot-Tech-Tips/238/Sizing-Circulators-for-Hot-Water-Heating-SystemsAll Steamed Up, Inc.
Consulting0
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 954 Plumbing
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
