Grundfos 15-10
NRT_Rob
Member Posts: 1,013
anyone using them?
seem like a good little pump... like a low speed brute, but only 25 watts of power usage, comparable cost.
horror stories? happy stories?
Rob Brown
in beautiful Rockport Maine.
injection mixing circ
is where I used a few. Hard to find on shelves and more $$ as they are not a common pump.Bob "hot rod" Rohr
I've used them
in several instances where I was trying minimize the operating cost and the low flow rate really wasn't a problem. worked fine. they are available in CI & bronze.0
- 167 Indoor-Air Quality
